1. Wrong door type
First and foremost, selecting the right storefront door is the initial step to a successful installation. Many business owners choose doors solely based on their aesthetic appeal and ignore essential factors such as durability, material quality, and climate suitability. Some of the factors to consider in selecting your door are:
- Material: Aluminum, steel, and glass each offer different benefits. Aluminum is light and corrosion-resistant, steel provides security, and glass improves visibility.
- Functionality: Do you require an automatic door for accessibility, or will a manual swing door be sufficient?
- Weather Resistance: If your storefront is exposed to extreme weather conditions, ensure your door is designed to withstand them.
2. Poor Measurements and Incorrect Sizing
Poor measurements can result in a door that does not fit correctly, leading to gaps, misalignment, or costly modifications. Always:
- Measure both the width and height of the doorway multiple times.
- Account for door swing and hardware in clearance space.
- Check measurements with a professional before ordering.
3. Violation of Local Building Codes and ADA Standards
Failure to observe local building codes and accessibility rules can lead to fines and expensive alterations. How to be complaint:
- Check door width, fire ratings, and accessibility requirements at the local regulation level.
- According to ADA compliance, your door must provide a clear opening of at least 32 inches wide.
- Install appropriate door handles, push plates, and automatic openers if necessary.
4. Misaligned Installation of the Door Frame
A wrongly aligned frame compromises security and productive functioning. Common mistakes include:
- Not being appropriately attached, thereby giving it a wobbly and improper alignment.
- Use of poor-quality material that deteriorates fast.
- Failure to observe the level and plumb aspect of installation results in improper door function.
5. Installation Without Weatherproofing and Sealing
Weatherproofing protects the strength and efficiency of your storefront door. Mistakes include:
- Incorrect sealing materials and water leaks or drafts do occur.
- Necessary seals around a door sweep or threshold are ignored, allowing dust and debris into your showroom.
- The frame is an area often overlooked in terms of insulation, with possible energy loss.
6. Lousy hardware
Hardware, including hinges, handles, and locks, is integral to providing security and durability. Mistakes to avoid:
- Replacing substandard or mismatched hardware that quickly wears out.
- Not using commercial-grade locks makes the storefronts an easy target for burglars.
- Ignoring the weight capacity of hinges and closers leads to premature failure.
7. Failure to Test the Door After Installation
After installation, always check to ensure it opens freely. Skipping this crucial step can cause:
- Jamming on the door during opening or closing.
- Unnecessary strain on a hinge and closer parts.
- Adjustments or repairs need to be made right away.
8. Failure to Hire a Professional Installer
DIY installation can seem like saving money, but improper installation may lead to costly future repairs. Professional installers guarantee:
- Knowledge of handling different storefront door types.
- Door warranty that the door is properly aligned and sealed.
- Compliance with building codes and industry standards
You can avoid costly mistakes on storefront door installations by ensuring they last long and are securely installed with smooth operation. By choosing the right door, providing accurate measurements, complying with codes, and engaging professional installers, you protect your investment while making your business more attractive. Quality installation must be prioritized to avoid unwanted expenses and keep your storefront functional for many years.
